It is currently Sat Jul 26, 2025 5:39 pm
PostPosted: Mon Mar 27, 2006 6:39 pm
I am sure that most would have already heard of using an old fridge motor as the basis for a vacuum clamping setup. Well, I was looking around the net and came across THIS SITE which has very simple instructions for making just such a vacuum pump out of very cheap and easily obtained bits and pieces. It is pretty crude but looks to be quite functional.
You could always upgrade the hoses and fittings and maybe add an old LPG cylinder as a vacuum reservoir. But if your main need was a small lamination press or bridge clamping jig, you could easily go with this design as is.
Cheap and Simple....hey! that's what my wife calls me
Cheers all
PostPosted: Mon Mar 27, 2006 10:01 pm
That is cool Kim. Thanks for the research and the idea.
PostPosted: Mon Mar 27, 2006 10:19 pm
Thanks a lot Kim. Good link and info. Got the DIY in me all excited now...
PostPosted: Tue Mar 28, 2006 3:34 am
That looks pretty easy to make.... maybe I'll give it a try!
Thanks!
PostPosted: Tue Mar 28, 2006 4:08 am
Thanks Kim, i'm a bit of DIYer myself too, looks challenging to me too!Thanks for sharing!
